Is this possible?
Discussion in 'Sky Broadband' started by SPURS1882, Jan 15, 2008.
  1. SPURS1882
    SPURS1882
    Sep 16, 2004
    395
    Gants Hill
    +16
    Hi All
    Would it be possible to get my Sky emails so that they are diverted to Outlook Express.
    If so, what is the procedure.
  2. md1542
    md1542
    Jul 13, 2005
    312
    28
    Gloucester
    +54
  3. Handle Bar Earl
    Handle Bar Earl
    Jan 10, 2008
    33
    +3
    Yes you can.
    Open MS EX, then select tools, then options.
    In here, click Mail services tab at the top. Then check profile to be used click SKY e-mail.
    Hope this helps:thumbsup:
