Is this Possible
Discussion in 'Home Cinema Speakers' started by Nobber, Feb 15, 2003.
  1. Nobber
    Nobber
    Nov 29, 2001
    317
    Rear Speaker Question
    I have two small rear speakers which I'm about to replace, is it possible to connect them together to be used as a rear centre?
    thanks
    Nobber
  2. magking
    magking
    Jan 6, 2001
    378
    Norway
    Yes, you can use them as the center rear.
    But when you say connect them together, do you mean on the same speaker out channel on the amp?
    If so the amp has to be able to drive two speakers at once on one channel, that might be a problem, especially if the speakers are 4ohm.
    What amp do you have?
    I have two surroun back speakers, but my amp has two channels of amp to drve them.
  3. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    I might be wrong but as long as they're connected in series you should be Ok, two 4ohm speakers connected as such producing an 8ohm load.
    spence
  4. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    Nobber ... you really shouldn't post the same question in two forums ... I've answered in the Amplifiers forum for you.
    Victoria
  5. Nobber
    Nobber
    Nov 29, 2001
    317
    SMACK!
    soz, I realised I posted in wrong forum first!
  6. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    If you post in the wrong forum ... correct ettiquette would be to delete the thread ... if you goto EDIT on your post there is a button at the top allowing you to delete.
    Anyway ... no harm done but just for reference for the future - stops you getting shouted at by the Mods ;)
    Victoria
