Is this possible?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sdfuk, Dec 8, 2004.
  1. sdfuk
    sdfuk
    Dec 6, 2004
    Quick question - does anyone know if I could directly connect a satellite to the Sony RDR-GXD500 as FreeView comes with it.?
    Or do I still need another decoder?
    Here are the specs
    Recording and playback of DVD+R/RW and DVD-R/RW
    Record in real-time using MPEGII compression: up to 6 hours per disc
    Built-in FreeView decoder and analogue tuner
    VideoPlus+ easy programming system
    Easy EPG recording control
    Simultaneous record and playback
    Chasing play feature (skip scenes during playback)
    Pre-Encoding enhancements: Time Base Correction, Pre Frame Noise Reduction, Pre Video Equalizer
    Post-Encoding enhancements: Frame Noise Reduction, Block Noise Reduction, Video Equalizer
    12bit/108MHz D/A Converter
    2 Scarts (full RGB) in and out
    Coaxial digital out
    Component video out
    Size(WxHxD): 43x9x38cm
    Weight: 5.1kg
    S
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Satellite is a completely different system to Freeview. You would need a Sky or Sky+ box and viewing card.
