Is this PC spec OK
Vinesh
I have spec'd up the following PC but cannot decide on the graphics card.
Would you guys go for a normal Bluray Drive or Blu Ray Writer?
BR Writers are around £85. Is it best to hold and wait for the prices to drop?
Usage -
AVCHD video editing 30%
Archive Blu Rays 50%
General Use 20%
Spec'd on Scan Computers.
LN29630
Xigmatek Asgard Black, Mid Tower, ATX Case with 4x5.25" 6x3.5" Bays inc 120mm Fan, No PSU
LN32202
4GB (2x2GB) Corsair DDR3 PC3-10666 (1333) Non-ECC Unbuffered, CAS 9-9-9-24, 1.50V
LN34338
Asus P7H55-M/USB3, Intel H55, S 1156, PCI-E 2.0 (x16), DDR3 2200(OC), SATA 6Gb/s, USB 3.0, mATX
LN34549
Intel i5 760, S1156, Lynnfield Quad Core, 2.8 GHz, 8MB Cache, Core Ratio 21x, 95W, Retail £123.15 £144.70
LN35692
500W Corsair CMPSU-500CXUK Builder Series, 80% Eff', 120mm Fan, Single Rail, ATX £39.95 £46.94
I will use my exisiting H/D's.
EndlessWaves
That depends on whether you're likely to use it straight away and whether you can be bothered to install one later. I'd imagine they'll drop to £30-40 within another year or two, although the price of the disks is still the real killer.
If archiving blu-rays is your primary use and likely to stay that way then it may be worth waiting for a writer as read speeds could well go up too.
Graphics card will make no difference for general use or blu-ray archival so that comes down to what sort and brand of card your AVCHD editing software can make best use of.
The rest of it looks OK at a glance, although the power supply will be rather on the beefy side if you don't end up going for a high end card.
Vinesh
Thanks :smashin:
I will be using this PC to edit AVCHD recordings from my Panasonic (1080p/50)
I think I will wait for BR-RW to come down in price.
As the PSU is on the beefy side, I will get a cheaper PSU and go for a better graphics card.
Does it matter on which graphics card I use for AVCHD.
Also this will be connected to U2311H (23" - Res 1920 x 1080 at 60 Hz)
Philips OLED807 Review, The High Price of Hi-Fi, Video Processors plus AV / HiFi News & More
