Is this PC any good..........
Discussion in 'Desktop & Laptop Computers Forum' started by paulg, Dec 29, 2006.
  1. paulg
    paulg
    As the title i need a new basic pc for the internet, e-mail, photos - as before the std bits and peices.
    I want Vista ( One all the major bugs are ironed out ) this pc has a free vista premium upgrade as PCWorld and seems a good spec and a good price.
    I was wondering what feedback you guys woudl have on this one -I dont want to buy a machine i need to build ( not technical enough )
    Let me know
    http://h10010.www1.hp.com/wwpc/uk/en/ho/WF06b/35123-35527-39847-39847-39847-12727100-77983297.html
  2. zeus123
    zeus123
    It doesnt say what speed DDR2 its using and im not too sure about the onboard graphics but overall these little Pavillions aren't bad.
    They are basically a laptop in a desktop case. Vista is a total hog on your resources, although the cpu on this system is good enough to run vista I personally would want something with a bit more weight behind it. The graphics card might hold you up a bit in vista too.
    Good system but not ideal for Vista.
  3. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    For surfing the Internet, emails and viewing photo's this should be fine.
    I wouldn't worry about graphics or the speed of the RAM for the basics you mentioned. If you wanted to start gaming or movies on it, then that's a different story.
  4. Vandiesel
    Vandiesel
    Jun 6, 2006
    1,470
    +40
    What price?
  5. Wholehearted
    Wholehearted
    Dec 29, 2006
    PC World Price
    Hope that link works - £700 in PC World with 19" TFT - not bad at all
  6. golden phoenix
    golden phoenix
    Aug 29, 2005
    12,587
    7
    2
    cheshire
    +4,884
    not an expert, but what about this at mesh for the same price plus delivery...looking to maybe get one myself!
    alternative?:D
    *edit*noticed my suggestion has less ram, but bigger harddrive and i think the pc world has a better graphics card. but worth a look on the mesh website anyway for all in ones, might see something else!
  7. stockyvillage
    stockyvillage
    Apr 6, 2006
    1,217
    liverpool
    +91
    the gs gpu"s are better than le ones
  8. paulg
    paulg
    Thanks everyone - I went for the HP PC its not bad does everything I want it to, Not a bad peice of kit for the price.
    Anyone looking for a good price reasosonable spec PC this one is good and the size makes it an alternative to a laoptop.
    Cheers for your help
