Is this Panny supplier any good?
Discussion in 'Plasma TVs Forum' started by tmurphy, Jun 21, 2003.
  1. tmurphy
    tmurphy
    Mar 5, 2003
    617
    Preston
    +92
    After a few weeks of pondering, reading reviews, reading comments on avforums, I've think i'm going to settle on the Panasonic 50PW5B 50" Plasma.
    I know the 6 series are due out in a month or so, so i assume the 5 series price will start to drop.
    The best price I've found is £5,500 at Techtronics, but i remember a long time ago not many people liked them.
    Are they any good these days? Does anybody know of a better price?
    I'll also be looking to get the pedesal and tuner box, but probably from other suppliers.
    Tony Murphy
  2. GASWATKINS
    GASWATKINS
    Mar 11, 2003
    245
    +10
    Dont touch them with a barge pole !!!
    They mucked me around with a DVD player 3 years ago
    They were appalling
    Thankfully all on Credit Card
    That was for £200 and you want to trust them with HOW MUCH !!!!
  3. encaser
    encaser
    Mar 15, 2001
    2,361
    116
    Suffolk/Essex
    +519
    If you search - particularly on dvd player thread - you'll see lots of complaints dating way back.
  4. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Tony,
    I"ve bought from them about 3 or 4 times over the years, dvd players mainly. Compet on price, never had a prob.
    However when I bought my Plasma recently I wanted a supplier a bit more local.
    Try Sound & Vision at Bolton (not that far from u), several plasmas on display, also should price match.
  5. tmurphy
    tmurphy
    Mar 5, 2003
    617
    Preston
    +92
    Thanks Lurcher, I had come across their website last night, bloody good offer on the Panny 503 MXE (after a search found the post about it on AVForums). Let's see if they can do as well on the Panasonic.
    Petty there not open on Sundays, otherwise I would be down there today.
    Tony
  6. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    If you're concerned about buying from the said supplier, have a look around this forum and you'll find several that are offering pro-active support!
    As for the said company, I've bought a DVD player form them and haven't had any problems, but a friend tried to buy one and kept getting fobbed off with delivery dates. He then went to someone else and had the player before the end of the week.
    Getting someone who also offeres advice on how to set up your screen is also worth the extra.
    All the best,
    Dr John Sim.
  7. KBDVD
    KBDVD
    Aug 25, 2002
    723
    Hertfordshire
    +6
    Hi tmurphy,
    I can recommend these guy's!
    They are currently selling the 50" @ £5,499 and I know that they are decent guy's to deal with as they gave me a full refund for my Panny 50" after 3 months use, when it developed a fault!........... You can't say fairer than that!
    PS: I'd really consider waiting for the 6 series (as I am) as the additional contrast ratio improvement & the expanded connectivity options (DVI-HDCP?) are set to be major improvements on the 5 series model, and I'll bet that the new model will come in at the current price point for the 5 series!
    www.letsgodigital.co.uk
    Best Regards,
    KBDVD.
  8. Spanjab
    Spanjab
    Apr 10, 2003
    33
    I had to get the local trading standards involved when I returned my Panasonic Tuner I got to go with the plasma. When it arrived I found the difference it made to the component picture quality was terrible so I am using the screen without it now. When I returned it to them they tried to charge me a 15% restocking fee because I had used tape on the box. Eventually after much grief and arguing they gave me a full refund but they didn't like it. 2 lessons, 1 don't use them and 2 don't buy the Tuner if you like watching DVD's in high quality.
