is this normal?
Discussion in 'Projectors, Screens & Video Processors' started by gioboy, Dec 30, 2004.
  1. gioboy
    gioboy
    hi just bought a epson tw .10 but there seems to be a lot of heat building up around the outer plastic and front vent is this normal?
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Projectors do get hot to the touch, especially around the out-vent which is where the heat is disip.. disp.. diss... expelled. ;)
    Make sure there's plenty of air space all round the unit...PJ
  3. charlaph
    charlaph
    May 29, 2003
    242
    Dundee
    Mine gets very hot above where the vent is (on the top) but I've had it on for many hours at a time without any apparent negative effects. I don't worry about it - just make sure there's lots of space in front of the vent.
  4. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    There's a 132Watt lamp inside, so it's going to get fairly warm. Just make sure that the airflow through the projector is unimpeded and clean the filer regularly.
