is this normal
Discussion in 'Arcam Owners' Forum' started by clancol, Jul 3, 2004.
Tags:
  1. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    I have just upgraded my dvd to a dv79 and am currently using it with a sr5300 and a paradigm sub.
    What i have found is the the bass from the sub seems to be less forcefull and has to be turned up a notch or two, but it does seem more controled. especialy in 5.1,
    also, overall soundtrack is quiter(at adverage Listing levels) but but can go louder than it used to without getting confusing.
    Is it normal for a 5.1 soundtrack to change when used with a better dvd player.
    I didn't think it would make that much difference.
    Don't know if that make much sence, as im really tierd.
  2. Polecatpete
    Polecatpete
    May 12, 2004
    476
    +5
    Hiya, I tried out a DV78 and noticed also it was much quieter than my existing player. No idea why and no one seemed to be able to help me when I enquired. All I could put that, and the sub down to was that it was just a much clearer and more detailed/controlled sound than my other player. Would be interesting to hear from anyone else who has experienced the same or better still, anyone who knows the answer!!!
    Rob
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I suspect that the difference you are hearing is down to an increase in clarity from a better player. I have found that a lot of customers who have been used to poor quality and sloppy boomy bass think that tighter and better controlled bass sounds like there is less of it.
  4. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    Clancol - why did you buy the DV79 and not the 78 ? I assume you dont need the HDMI connection - are there any other differences apart from this ?
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The sub output on Arcam players is -18db for 5.1 and -6db for stereo when the onboard bass managenent is engaged. This is because they have to limit all the analogue outputs to 2.2V (Dolby rule) and the sub level could go much higher than this because of the sum of all the channels.
  6. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    i did want the hdmi conection.
  7. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    Ok. I suppose thats one of the major benefits of the DV79 over the 78. I too went for the 79.
  8. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    The DV79 is also a DVD-A player. The DV78 is not.
