antony110
Hi AVForums, last friday i purchased a samsung qe55q9fn and was wondering if pic related is normal (lightbleed from the sides and noticeable banding/uniformity).
Imgur
a friend of mine has the exact same model and it seems like his doesn't have this or at least not as bad.
since the q9fn is supposed to be the high end model of samsung is this a good enough reason for a refund/return? or did i get bad luck with the panel lottery and the "in spec" argument will be used by my retailer.
would really appreciate it if someone could help me out with this
Imgur
