Is this lens any good?
Discussion in 'Photography Forums' started by mitesh, Aug 4, 2013.
  1. mitesh
    mitesh
    Aug 5, 2008
    131
  2. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Would rather the 70-200 2.8
  3. Ugg10
    Ugg10
    Apr 17, 2009
    3,204
    +1,566
    I'd go with the canon 70-200 f4 IS L for the same money (if you search), you loose a stop of light but the IS and speed/accuracy of focus is great. I love mine.
  4. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
  5. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    Tricky one, the 50-150mm is a little sharper I believe, wider focal length at the wide end.. that's more useful for a wedding say or other social event. It's a little cheaper ( I'd buy from here if I was getting one - Camera Lenses :: Sigma :: Canon Mount :: Sigma 50-150mm f/2.8 EX DC OS HSM Lens for Canon - Onestop Digital )
    On the other hand it's heavy, same as the 70-200mm (same casing), the 70-200mm is fair bit longer at 200mm and crucially can be used on a full frame camera if you ever upgrade.
    If you don't need f2.8 then the Canon 70-200mm F4 L IS is definitely worth a look as well, better build quality and faster more accurate AF + a lot lighter.
  6. mitesh
    mitesh
    Aug 5, 2008
    131
    I have the Sigma ex F2.8 in the 17-55mm and love it....so am a bit confused!!
  7. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    What are you confused about?
  8. mitesh
    mitesh
    Aug 5, 2008
    131
    The sigma has f2.8 but the canon has more reach?
