Is this Hardware ok?
Discussion in 'Microsoft Windows' started by Spies, Aug 22, 2005.
  1. Spies
    Spies
    Aug 8, 2004
    291
    +8
    Looking to build an MCE box with the following hardware:
    LN9958 HiperMedia Chassis, Small Form Factor(AMD Validated) Matt Silver Finish, for Micro-Atx/Mini-Itx MoBo £46.88 £55.08
    LN10441 MSI RS480M2-IL uATX S939 ATI R Xpress200 DDR400 PCI-E SATA Raid 5.1Ch Audio Lan USB2/1394 £53.05 £62.34
    LN8447 Microsoft Windows Media Center HARDWARE Kit (Remote/Receiver) OEM £18.85 £22.15
    LN10610 Pioneer DVR-K05 Slimline Slot Loading x8x8 DVD+-R and x4 Dual Layer (Not Hoojum Compatible) £57.00 £66.98
    LN10546 AMD Athlon 64 3000 32/64Bit CPU S939 "Venice" 90nm Retail inc Heat Sink Fan & 3 Years Warranty £86.30 £101.40
    LN10612 320Gb Western Digital Caviar Special Edition WD3200JD-FDB (7200rpm,8MB) - SATA £92.01 £108.11
    LN11237 512Mb Corsair VS, DDR400 / PC3200, 128Mx64, non-ECC, 184 DIMM, unbuffered, CL2.5, Lifetime Warranty £29.11 £34.20
    And a Hauppauge PVR-250.
    Are there any potential problems in the above configuration I should be aware of?
    Hope to output sound over SPDIF to the AMP for 5.1.
  2. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Thats seems fine I would use 2 hd's though if you can fit an extra one in the case 1 for the System one for videos etc.
    AMD 64 939 excellent CPU run very cool and can overclock quite well if needed.
    I would go for the PVR-350 instead or NVTV card.
  3. Spies
    Spies
    Aug 8, 2004
    291
    +8
    I already have the PVR-250 though ;)
    Am I going to have any problems getting 5.1 out of AC97?
  4. OneEleven
    OneEleven
    get 2 x 256MB DDR400 rather than 1 x 512MB module - this will allow you to run the board in dual channel mode.
    I think with the hipermedia you need to by a PCI riser (it comes with and AGP riser) and a heatsink.
    The only thing that worried me about the hipermedia case when I was looking is that there is only one heatsink available, and I wasn't clear how quiet it would be; especially as it's very slimine; oh and you can only fit one HDD in the case.
  5. Spies
    Spies
    Aug 8, 2004
    291
    +8
    Hope to use Cool & Quiet if it doesn't make any issues.
  6. nigelbb
    nigelbb
    Apr 4, 2005
    5,269
    103
    +490
    I think that I mentioned this in another post when the Hauppauge WinTV PVR350 was recommended but it's not worth the extra money versus a PVR 250 (which you have in any case:). The 350 is a 250 with a hardware MPEG2 decoder & TV out. However these features are not used or supported in MCE. The PVR250 has been aon the market for a few years now, has decent quality & has lots of support from other PVR applications if you get fed up with MCE:)
  7. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Also 2 sticks of memory will use more volltage check with the wattage checker before making all your purchases as the PSU may not hanlde all your components.
    PVR-350 also has radio tuner where the PVR-250 doesn't but if you already have the card go with that it has same chipset as the PVR-350.
  8. meansizzler
    meansizzler
    May 11, 2005
    7,588
    104
    London
    +266
    Not bad for under the £500 Mark..
