is this hard drive ok for 360?
Discussion in 'Xbox Forums' started by bearman3784, Jan 12, 2008.
  1. bearman3784
    bearman3784
    Dec 18, 2007
    5,813
    Hitting the Eastside of the LBC
    +1,649
  2. Mac User
    Mac User
    Sep 27, 2006
    4,551
    Norfolk
    +309
    Yeah, I cant see why not.. Just make sure you format it as fat32
  3. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    Any USB drive will work, if you plan on having any files larger than 4GB you'll want to format it in HFS+ using transmac rather than FAT32.
  4. HDPio
    HDPio
    It will be fine aslong as it is Fat32. If you have a X264 MKV file you can use Gotsent which will convert the file to a suitable format AND split the file so you wont need to reformat your hdd.
  5. bearman3784
    bearman3784
    Dec 18, 2007
    5,813
    +1,649
    thanks, i tried gotsent on a mkv file but couldnt find where it saved the converted file to :rolleyes:
