Is this going to work?
Discussion in 'Plasma TVs' started by adamski71, Mar 19, 2005.
  1. adamski71
    adamski71
    I was looking to buy a 42" plasma so I did the usual,
    went to currys, comet, etc. walked out confused.
    So I read these forums and need some advice.
    I have NTL (samsung box), a cheap (scart) DVD and a BOSE dolby sourond system.
    Will this work/be enough to get me going?
    AVForums Panasonic TH-42PWD7 Plasma Screen
    (TH-42PWD7BK) - TH-42PWD7BK Charcoal Finish
    (OPB2B) - Charcoal Stand
    (QUINTRO) - Quintro+ RGB Switch Box +£83.66
    (JS-RGB-VGA) - RGB to VGA JS Converter Box +£110.15
    Total cost 1707.88
  2. hermanmunster
    hermanmunster
    Dec 23, 2004
    499
    Somewhere sunny and warm...I wish
    +24
    This will do the job very nicely.......and then the bug bites and you spend more money chasing the perfect picture.....but I digress. Good screen, good retailer what are you waiting for?? :smashin:
  3. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    tis great but you'll soon be after a component output dvd so maybe just as well to add a component input board to the order if they have them as getting the boards individually afterwards never seems to be easy...and if you're spending that amount anyway another £150 or whatever isn't going to make much difference.
  4. frank-g
    frank-g
    Feb 13, 2005
    112
    16
    Isle of Dogs
    I got my PWD7 from AV a few weeks ago and have been having discussion about going on to component. Ref thread `How do you watch DVD's on your Panny PW6 / PW7?` (thanks for advice mep).
    I have been quoted £100.04 for BNC component board and 1m Van Damme RCA-BMC cable from AV, so you with still get a good discount from them if you buy add ons later.
    Adamski. I would look at how many things you will want to connect via scart, at the moment I only have Freeview PVR and DVD palyer. If I go over to component the Quintro+ box basically becomes redundant.
    I got the 3 year warranty and would consider that a worth while extra for peace of mind (and transfersable should I sell screen).
  5. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    thats a real good deal frank!...is that the 1 socket component board?
  6. c4lln
    c4lln
    frank, check av sales for the bnc board, got mine this week for 85.
    regards
    chris
  7. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    chris, i think that's where he's getting it...but witha cable thrown in for £100...sounds good as the van damme cables are £40+ IIRC
  8. frank-g
    frank-g
    Feb 13, 2005
    112
    16
    Isle of Dogs
    Chris, the board is £66.49 and the cable is £33.55, from AV-Sales.
    mep, the board number is TY-42TM6AB. I think if I remember correctly, from their pic, it is a 1 slot board.
  9. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    cheers mate, may get one myself...always useful to have a spare input...
