Is this for real or what
rct
Does look like a bargain!
Personally wouldn't go for a Sony, but if that's what you've chosen then go for it!
Make sure you buy with a CREDIT card not a debit/charge card, so you have some fall-back should anything go wrong. I noticed that the retailer is a member of RETRA as well (Radio, Electrical & Television Retailers' Association) and their members have to comply with a code of practice etc. http://www.retra.co.uk/code_complete_con.htm
Also do a search for the name of the retailer on the forums to check if there is anything to look out for.
Good luck ;)
LV426
Administrator
Staff member
M
maximus desimus
hi
yhanks for the repys
yes i ordred last nigth rung them and there in stock also got the free vcr ,
Regaurding the price its the best one i could find online with price runner
thanks again.......
mh66639
Would anyone have a cached copy of this offer? I'm gonna try a price match if I can get the HTML?
If anyone need technical help to do this, please say.
REALLY Appreciate any help!
Matt.
lynx
Bad timeing.I've just cleared temp files and index.dats or you could have it.
mh66639
...just don't defrag your drive, and we should be able to reassemble then byte-by-byte... :)
Matt.
M
mattheu
John Lewis price matched RGB direct as they have a shop front, at £1579 ( + 5 year War..) Last looked at RGB ( last week)and its now 1569?
What free VCR , was that a Sony offer?
