Is this component cable OK?
Discussion in 'TVs' started by Hitcher, Aug 19, 2003.
  1. Hitcher
    Hitcher
    Jul 6, 2003
    65
    11
    Eastleigh
    Is this cable any good for connecting from my component switcher to my TV?
    If not, can you recommend one for about £20.
    PS My TV is a Toshiba 28ZD26P.
  2. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    I wouldn't bother getting cheap and nasty cable like this for component use.
    You should spend at least £30, especially for such a nice TV as the Tosh.
    Try Techlink's component lead for about £30. :)
  3. Hitcher
    Hitcher
    Jul 6, 2003
    65
    11
    Eastleigh
    Cheers, do you have a link?
  4. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    Yes, I have a Tech LINK!!!!
    Ha, ha, ha-ha, ha-ha, ha......
    Oh never mind!
    http://www.techlink.uk.com/techlink products/home_cin/home03.html
    We sell Tech:Link in our store. Obviously you can buy much better, they are pretty decent and a minimum for component use I feel.
    You may have seen JS Technology's RGB/Component etc. highly rated convertor boxes being mentioned on the forum. They use Tech Link cables to test their boxes.
    PS. CHECK THE PRIVATE MESSAGE I SENT YOU!
