Is this Cat6 cable any good?
Discussion in 'Cables & Switches' started by jasser, Feb 8, 2014.
  1. jasser
    jasser
    Nov 22, 2005
    28
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,081
    Poole
    +10,940
    'CCA' is copper coated aluminium, dodgy if the termination isn't right.
    CAT6 Cat 6 UTP COPPER Ethernet Network SOLID Cable Reel BOX 305m - CAT6-305m -Networking - Wired, Cables (Patch and Reels), Network Cables Reels, CAT6-305m from kenable
    That is copper, significantly better.
    The other consideration is that the jacket looks weak so you need to take care when pulling the cable through.
    Cable Monkey are decent and sell branded Connectix cable:
    Cat6 UTP PVC Solid Cable (Box)
    They also sell 100m reels but remember to allow for VAT. 100m is £38+VAT.
  3. jasser
    jasser
    Nov 22, 2005
    28
  4. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,081
    Poole
    +10,940
    Yep, the second picture shows 1000ft marking and the datasheet shows 305m (OK, 304.8m!).
    It is solid copper with a high density polythene jacket so looks good.
  5. jasser
    jasser
    Nov 22, 2005
    28
    Thanks again Trollslayer. I'll get some of that
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,752
    The Borders
    +3,519
    The GigaTrue cable is good - there are matching RJ45 plugs too.
    We tend to run multiple runs so order multiple colours to make it simple to identify.
    Joe
  7. jasser
    jasser
    Nov 22, 2005
    28
    Thanks Joe
    4 boxes arrived today - one of each colour
  8. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,389
    Inbetween Upgrades !
    +9,560
    Are the GigTrue cat6 patch cables very flexible ?
  9. jasser
    jasser
    Nov 22, 2005
    28
    Well I've opened up a box and yes fairly flexible. Certainly a lot firmer than a Cat5 patch cable. Should be able to run then no probs. There's a warning on the side of the box about not using too tight a radius on the bends
  10. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,389
    +9,560
    Only asking because I got a 5mtr cable from a certain supplier and it arrived wound up very tightly inside the packet. It's now like a coiled spring, never going to be straight again.
