Is this case ok for HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by dUnKle, May 23, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    This one here
    I am wanting to take apart my old desktop tower PC and transplant all the pasrts into a case that could slide into my equipment rack
    Will be taking a P4 2.6GHz 1024 MB ram with a rad 9800 Pro, Creative Audigy 2 - 1 x DVD Drive and 2 X 160GB HDs - not sure what the technical term for the motherboard is but it takes up fair amount of the tower case
    Would this case be suitable
    I guess I would also have to transplant across my PSU as well
    Im looking for a nice looking case - ideally no more than £55
  2. DaveP
    DaveP
    You can save some money here
    Dave
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    blimey - good spot
    and will they work ok ? be big enough to fit all I have
    will 350W be enough or should I go for better PSU
  4. justin@hc&b
    justin@hc&b
    Sep 6, 2003
    415
    Birmingham
    +12
    sounds like you have an atx board and that case is micro atx so it wont fit =( i cant really say what other cases to look for around the sort of money you want to spend but you need to be looking for atx if you want to use your current gear .. have you looked at the silverstone range of htpc cases some nice stuff there maybe streching your budget a little tho
    justin
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    cheers
    saw that just
    may have to up the budget
  6. DaveP
    DaveP
    I'm not sure why you think it is an ATX board. He only has a graphics card and sound card.
    DuncanWardle, how many slots do you have on the board?
    mATX has 3 PCI and an AGP.
    Dave
  7. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    3 PCI and 1 AGP is what I have - board is about 9" sqaure at a guess
    Also - can Not have a case more than 170mm in height due to shelf space - which rules out this one here does the height of this take into account the feet - if it does I am fine if not im not
    if I up my budget to £100 what could I get ?
  8. DaveP
    DaveP
    You have to be careful with the height. You'll need one that takes full height cards or you will be looking for a new graphics and sound card!
    I thought about buying this one here but it's too expensive for me and it may be too big for you.
    Dave
  9. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    can not view that link
    If 170MM of the thermaltek is with the feet I will be fine and everything will fit - if not I need another case - ideally looking for one with no pull down front panel but guess can not have everything
  10. Baloo
    Baloo
    Aug 22, 2003
    767
    28
    Bath
    +33
    I have that one in silver and its great as long as you have a mATX board. My PCI slots house two Black Gold digital cards and a sound card. AGP slot has a graphics card, all you really need for a HTPC. Can really recommend xcase too as a good supplier.
  11. dUnKle
    dUnKle
    Jan 1, 2001
    15,222
    +2,249
    dont think mine is an matx :(
  12. DaveP
    DaveP
    That IS an mATX board
    Dave
  13. justin@hc&b
    justin@hc&b
    Sep 6, 2003
    415
    Birmingham
    +12
    you trying to trick me saying that ;)
    as dave says 1 agp and 3 pci is micro atx
