Is this cable directional?
Discussion in 'Cables & Switches' started by Anders0n, Aug 28, 2005.
  1. Anders0n
    Anders0n
    Aug 12, 2005
    181
    Gloucester
    +4
  2. loadsofleads
    loadsofleads
    Most cables that have different connections on each end are one directional only, but it might be worth contacting the retailer and checking. :)
  3. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    The problem with Scart Leads is they will have seperate Transmit and Receive pins. If you are using phonos at the other end the lead will have to be directional so that the signal ends up on the correct pins.
    You should be able to fid one that works the other way round though.
  4. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    No This cable is not directional.
    There are only one set of pins for RGB scart interface. It is up to the equipment to know wether to send something down it, or look at whats coming in.
    Gareth.
