Is this bracket suitable for my old Toshiba?
PlasmaIan
Its time to move my long serving Tosh Panel 42WP16 to the kids room and I require a fixed wall bracket for a brick wall. Saw this advert for £30 and wanted some confirmation it is suitable. From what I have read in the forums you just pop out the 4 plastic covers in the corners and screw the bracket on ? is it this easy ? I presume all the brackets have some adjustment slots to enable the horizontal to be found correcting any slight drilling errors.
advice please
TOSHIBA TV Wall Brackets / Mounts Suitable for TOSHIBA 42 inch ALL MODELS TV
Member252055
Although listed as a Toshiba bracket this is basically a universal Plasma mount of which there are many available. Basically you bolt the vertical arms onto the back of the TV using whichever slots/holes line up. Then you hook these onto the wall plate which you've fixed to the wall. Usually there's some adjustment in the wall plate fixing holes for levelling.
M-Form - 32" to 50" Universal LCD/Plasma Bracket
All our brackets benefit from Free Delivery and our unique G-Fit Guarantee - If it doesn't fit, we'll make it fit, free of charge!
Best Regards
Graham
PlasmaIan
Thanks for your reply - looked at your site and will be placing an order - what size fitting kit do I neeed for securing to en external brick wall 8* 50 at £9 ?
