Is this better?
Discussion in 'Blu-ray & DVD Players & Recorders' started by geordie boy, Jan 26, 2005.
  1. geordie boy
    geordie boy
    Help!
    I'm looking to set up my dedicated cinema room and have just got myself a Panasonic AE 500 projector.
    I'll be runninng a Yamaha DSP-AX1 to a 6 speaker mission set up and ruark sub.
    Question is - and funds are running short - I have a Yamaha DVD-S520 dvd player which I could connect to the projector via scart to scart and optical out to the amp but...
    Is this a better player - Toshiba SD-240E - as it is PAL progressive and has Component video (and I have a profigold component cable)
    I know you will all recommend I save up and buy a decent player, which I will, but not for a few months yet.
    What do you think?
    GB
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Tosh 340e multi region-£75.00 or pioneer 575 £100.00.Both excellent almost disposable at the price.
  3. LITTLEBRITAIN
    LITTLEBRITAIN
    Nov 28, 2004
    310
    19
    Greater Manchester
    i would look at a pioneer dv370 as its got the same guts as a dv575 but without the dvda/sacd and divx playback. can be got for around £69.95 poss less?
  4. geordie boy
    geordie boy
  5. geordie boy
    geordie boy
    anyone else?
  6. geordie boy
    geordie boy
  7. geordie boy
    geordie boy
    so then 240e at £40, 340e at £70, dv370 at £70 ??
