Answered Is this banding?
Discussion in 'OLED TVs Forum' started by DougAP, Jul 13, 2018.
  1. DougAP
    DougAP
    Oct 14, 2012
    1,628
    116
    +826
    I picked up a Panasonic 65 EZ952b the other day and had intended to avoid checking on slides for banding. However, I noticed a vertical line in some content (it's not noticeable most of the time), so I had to check slides to be sure.
    The TV was on offer as it was sold ex-display, although I was assured it had just been put on display and was free of any issues/image retention. So I'm not sure whether what I'm seeing is banding (I'm guessing it is) or some form of image retention. What do you guys think? And would you think this acceptable?
  2. Best Answer:
    Post #5 by wezzywebb, Jul 13, 2018 (1 points)
  3. wezzywebb
    wezzywebb
    Feb 12, 2004
    8,354
    2
    fishburn
    +8,518
    Yes it’s banding ,has the set done any compensations since you got it ?chances are with it being ex demo it won’t have done any on display
  4. DougAP
    DougAP
    Oct 14, 2012
    1,628
    116
    +826
    Thanks for the quick response. Not so far as I'm aware - I've only had it two days.
  5. DougAP
    DougAP
    Oct 14, 2012
    1,628
    116
    +826
    Here's a 10% slide.
  6. wezzywebb
    wezzywebb
    Feb 12, 2004
    8,354
    2
    fishburn
    +8,518
    Best Answer
    Make sure the set goes into standby ,thats when compensations run,do that for a couple of days and see if it improves
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  7. DougAP
    DougAP
    Oct 14, 2012
    1,628
    116
    +826
    Great, will do. Thanks!
  8. Jase
    Jase
    Mar 16, 2001
    10,956
    United Kingdom
    +3,417
    In case you weren't aware. The Power/Standby LED will also turn orange/amber whilst it's doing the compensation.
    • Thanks Thanks x 1
    • Useful Useful x 1
    • List
  9. DougAP
    DougAP
    Oct 14, 2012
    1,628
    116
    +826
    I wasn't. That's very useful to know though, thanks. Is there any way to tell when to expect it and at what intervals compensation will occur?
  10. Jase
    Jase
    Mar 16, 2001
    10,956
    United Kingdom
    +3,417
    It's usually after every four hours of use and will kick in automatically when you put it into Standby.
    I'd see how it pans out after it's done a few. Mine had a couple of light bands which were visible in some content (Tennis and Football) but they've now gone.
    Personally, I'd avoid running the long manual compensation and stick to the auto ones.
  11. DougAP
    DougAP
    Oct 14, 2012
    1,628
    116
    +826
    That's reassuring to know that you had it to but then it went. The compensation should be running more or less every night then. I hope the band does go because, otherwise, I'm very impressed with the Panny.
  12. Jase
    Jase
    Mar 16, 2001
    10,956
    United Kingdom
    +3,417
    I've got the 55 inch version and it's capable of some stunning images. It has better out of the box colour than my LG E7 (which is already rather good) and I think it's upscaling is also better. Both have their Pros and Cons but I rather like the Panasonic...:)
