is this any good...?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lee J B, Aug 28, 2004.
  1. Lee J B
    Lee J B
    I purchased some DVD-RW discs (TDK RW's from Virgin - five for £6.99). During playback the recording froze and error message popped up informing me the disc is either 'pysically damaged or dirty'. It wasn't dirty, so it must be the disc. I'm assuming it's because it's a cheap and therefore low quality(?).
    I've been browsing amazon for dvd-rw discs and came across this one:
    The Disc In Question
    Anyone know if it's any good? If not, feel free to recommend one - and where i can purchase!
    Thanks,
    Lee
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    TDK disks are normally top-quality. What DVD recorder/DVD burner are you using?
  3. Whitetop
    Whitetop
    Jul 16, 2004
    Imation are ok m8, but i use Datasafe 4x rw at a better price from HERE :thumbsup:
  4. Lee J B
    Lee J B
    I've got a Toshina DR1. On the recording which messed up i did forget to stop it, so it basically kept recording till the disc reached the end of its capacity...could this be why the recording went wrong?
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Probably not - the Toshiba DR1 is known to be quite fussy over it's DVD-RW media. As and when you find a brand of them it likes then they should behave as you expect.
