is this any good?komplett htpc kit?
Discussion in 'Desktop & Laptop Computers Forum' started by TopMeTom, Jun 16, 2005.
  1. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
  2. Skunkpipe
    Skunkpipe
    That's not a bad starting point. The Sapphire board is exactly the same (minus fireware) as the EQS/Optronix boards which are highly rated for HTPC.
    Silvertsone case is nice (but huge), the only thing I couldn't comment of is the PSU, but for £515 it's a good buy I'd say
  3. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    Anyone else?Or any other recommendations people?
  4. lisag
    lisag
    Jul 14, 2004
    5,558
    Essex
    +296
    What software were you planning on using for your 'front end' that is the GUI where you access all your media files (via remote control usually)? If you were thinking of using Windows Media Center Edition, not sure if all these parts are compatible. If you are using something else it will probably be fine.
    lisa
  5. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
  6. lisag
    lisag
    Jul 14, 2004
    5,558
    Essex
    +296
    Well you have an infinite amount of options open to you, maybe you should think about what you want to use it for, and how you want to operate it, and how much you want to spend?
    I use Windows MCE on a shuttle, it was quite a budget buy (relatively) and works very well (eventually) but.... there are plenty of other options.
  7. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    I like budget:)
    where did you get yours from,if I may ask?
  8. lisag
    lisag
    Jul 14, 2004
    5,558
    Essex
    +296
  9. Razor
    Razor
    Dec 15, 2004
    37,545
    2
    +12,498
    I would swap the 6200 geforce for a 6600gt fanless as this card is good at displaying HD material.
    Nice to see these companies doing a bundles, it should bring down prices of ready made HTPC's.
