Question Is this amp ok for these speakers?
KamSandhu44
Established Member
Hi all,
I have decided on some speakers and wanted to see if the amp I wanted is ok to run them.
The speakers are -
Fronts - Q ACOUSTICS 3050
Centre - Q ACOUSTICS 3090C
Rears - Q ACOUSTICS QI80C
Sub - Q ACOUSTICS 3070S
The amp is YAMAHA RXA850. Last thing I want to do it over power or under power them.
Open to all suggestions.
Member 729553
Established Member
Hello KamSandhu44
Firstly; thank you very much for choosing Q Acoustics loudspeakers.
Secondly, regarding the Yamaha RXA850, it's an excellent home cinema amplifier and will be an ideal match with the speakers you've selected.
best regards
KamSandhu44
Established Member
Thank you, are there any other amps to take in to consideration?
Member 729553
Established Member
All the major amplifier manufactures (Denon, Yamaha, Onkyo, Sony, Pioneer and others) are making very good products. But at its price, the RXA850 really does seem to be the best currently available.
best regards
simonlewis
If you want Dolby Atmos, DTS:X and for it to be pretty future proof then consider the Denon AVR-X3200W.
KamSandhu44
Established Member
That Denon amp looks rather tasty. But unfortunately for me Atmos or a decent DTS:X isn't an option for me. I don't have the room for it. I will be sticking with 5.1
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
