Question Is this a problem with Av receiver or sky box?
Discussion in 'Sky Digital TV Forum' started by Such, May 2, 2016.
  1. Such
    Such
    Dec 27, 2003
    2,387
    63
    Greenhithe
    +162
    I posted this in the amp/receiver forum, but thought I'd try here too:
    I have my denon x5200 connected to my samsung H7500 (via new evolution box) and devices going through the denon.
    The sky box input is set to passthrough on the denon.
    I have been getting display hdcp 2.2 error messages frequently when starting a "watch sky" activity on my harmony. This is with the denon off. I have to restart the box and it is then ok. Also switching on the denon then shows sky programs.
    I am also experiencing sound drop outs when watching with amp on and via passthrough. This happens infrequently, but when it does, the sound will drop out often enough to spoil what is being watched. rewinding and then playback the sound is ok. Connection is via HDMI and optical.
    This does not happen on any other source.
    Denon suggest it may be a problem with the HDMI board, but could it be the sky box? I've had the sky box since june 2015
  2. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    See Rule 8 - which one do you want to keep?
    As a first step disable HDMI-CEC if not already done.
  3. Such
    Such
    Dec 27, 2003
    2,387
    63
    Greenhithe
    +162
    Sorry was not aware of that! thought I might this may be a good place to post just in case it was a Sky box issue.
    HDMI control disabled on all devices
  4. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    Yes, this is OK.
    Why do you have both HDMI and optical?
  5. Such
    Such
    Dec 27, 2003
    2,387
    63
    Greenhithe
    +162
    I don't seem to get 5.1 using HDMI. If i set HDMI to 5.1 on the sky box, I get no sound on the TV when amp is off. setting HDMI to normal passesn sound to tv when amp is off.
    So I use optical for 5.1
    I'm sure there must be a way around this?
  6. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    I use the amplifier all the time for Sky.
    Can't you do this without using the passthrough setting?
  7. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,560
    Oxford
    +1,327
    All that means is that your TV cannot decode the DD signal and needs normal stereo. What happens if you connect Sky box direct to TV? Simple diagnosis to see whether fault is with Sky box or Denon.
  8. Such
    Such
    Dec 27, 2003
    2,387
    63
    Greenhithe
    +162
    I could but don't want to use the amp all the time for normal TV
    I'll try that for a week and see how it is.
  9. Such
    Such
    Dec 27, 2003
    2,387
    63
    Greenhithe
    +162
    So far no probs with sound drop outs or HDCP errors,
    looks like amp going for repair next week:(
