Is this a good progressive scan DVD player.(help please)
Discussion in 'Blu-ray & DVD Players & Recorders' started by brad123, Feb 15, 2002.
  1. brad123
    brad123
    Jan 29, 2002
    3,948
    68
    West Yorkshire
    +63
    Nintaus PDVD-N9769
    https://www2.setssl.com/~hivizone/dvdplayer/main_frame.htm
    Powered by Sage's FLI2200 de-interlacer with DCDi™ technology by Faroudja.
    Powered by Zoran VADDIS IV DVD decoder.
    Outputs both PAL and NTSC progressive signals.
    Built-in HDCD decoder.
    Built-in PAL-to-NTSC and NTSC-to-PAL converters.
    I believe it uses chips etc that are in higher priced progressive scan players. Its to go with my new panny pj as ive been told the picture will be far batter with a progressive scan picture through component leads rather then my current s video connection from my toshiba SD100E...Correct???
    Is it better then the new lecson coming out soon with progressive scan for £200.
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    No one has seen this player yet so no one can comment. I think one person has ordered one but it won't come for a week or two. It certainly has some interestuing bits (Faroudja) but whether it is better is purely down to Engineering and how it has been made / designed etc. Specs may be better than a Tag but I know which i would rather have.;)
    Hang fire for a few weeks and there may be some first hand reports coming through.
  3. brad123
    brad123
    Jan 29, 2002
    3,948
    68
    West Yorkshire
    +63
    anymore info on this player or any tat will suit my needs.
