Is this a good price?
Discussion in 'Plasma TVs' started by cwoj, May 24, 2004.
  1. cwoj
    cwoj
    One of my suppliers is selling a NEC 42" pLASMA 42VP4D (black/silver) 42 XGA for £1,895 + Vat?
    Is this a worth while buy or better to hold out for a panny :thumbsup: ?
    Chris
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    as far as i know, it isnt an XGA display
    ad
  3. cwoj
    cwoj
    has this spec...
    42-inch screen with 16:9 aspect ratio and CCF™
    853x480 pixel resolution
    89 mm thin, 28.5 kg light
    Professional component and domestic video input
    Computer inputs
    VGA, SVGA, XGA, SXGA, UXGA, NTSC, PAL, SECAM and HD compatible
    Digital zoom presentation tool
    Digital DVI graphics input
  4. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    as i said, not XGA, only VGA. If it were my money I would prefer to go for the panasonic which is only about £150 more
    ad
  5. cwoj
    cwoj
    now then the question is which model? do you have any thoughts on the 42PWD6? Which terminal boards would give me the better picture?
    I am planning to use this with the denon 3805?
  6. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I have that model, i havent been able to test it properly just yet but brief viewing gives very good impressions. I had £2500 to spend and this was my machine of choice. This seems the top choice until you spend £3k+ at which point the new pioneers challenge as well as the panasonic HD model (Gordon sounded very impressed by this).
    ad
  7. cwoj
    cwoj
    Ad, cheers for the response....but whoch boards would i need / be better going for?
