Is this a good price for a Av-32r-bp-192-Dp
Discussion in 'TAG McLaren Audio Owners' Forum' started by pidge22, Sep 29, 2004.
  1. pidge22
    pidge22
    Jul 14, 2004
    1,248
    48
    Near Nottingham
    +25
    I have the chance to buy a Av-32r-bp-192-Thx ultra2-Dp-7.1 for 3000 pounds,is this a good price to pay or can I get cheaper?
    It has basically everything loaded and bar Dab radio everything else installed.
    With regard to Tmreq I initially plan to use it in a 5.1 system (upgrading to 7.1 in the near future) will it make any difference with the fact this is a 7.1 versiom?
    Pidge22
  2. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Its not a bad price but you could do better, it retails at £4000.00. I got my AV32R a couple of years ago for £1700.00 ex dem and it was a 7.1 96khz(before I had it upgraded :D). I recently got my DVD32R RRP £4300.00 for £1650.00. I think if you shop around you should be able to pick one up for £2500.00 or less :smashin:
