Is this a good monitor? (Proview 19" FV-926FW)
Discussion in 'LCD & LED LCD TVs Forum' started by SleepMaster5000, Mar 27, 2006.
Tags:
  1. SleepMaster5000
    SleepMaster5000
    Hi, Im looking in to buying a new monitor for normal PC usage and my Xbox 360, i was at future shop, and they had a Proview 19" Widescreen LCD Monitor (FV-926FW) for 399.95 Canadian and im wondering if thats a good monitor (never heard of the brand, thats why i ask). It looks great and its widescreen, plus as a bonus it has 2 VGA inputs and a DVI input so i dont need any splitter stuff. So yeah, any opinions on this?
  2. SleepMaster5000
    SleepMaster5000
    just found the exact specs for it
    Size
    Size (inch) 19 w
    Panel Spec. (For Reference)
    Display Area 410.0x256.0
    Max. Resolutions 1440 x 900
    Display Colors 16.2M
    Response Time (ms) 8
    Brightness (cd/m²) 300
    Contrast 500:1
    View Angle : H 75/75
    View Angle : V 70/60
    Dot Pitch (mm) 0.285x0.285
    Panel Surface ANTI-GLARE
    Horizontal Freq. (KHz) 30~82
    Vertical Freq. (Hz) 56~75
    Others Spec
    Protective Glass NO
    Built-in Speakers YES
    Stand: Arm+Base PLASTIC
    VESA Mount (mm) 75x75
    I/O Port
    Compatiblity PC/MAC
    Analog Input D-SUB x2
    Digital Input DVI-D
    PC Audio Line-in YES
    Power
    Consumption 60W
    Voltage AC100-240V/50-60Hz
    Others
    Regulation FCC-B, UL/cUL, CE, CB, TUV/GS, GOST, TCO'99
    Package
    Monitor WxHxD (mm) 457x371x210
    Packing WxHxD (mm) 532x500x140
    Net Weight (KG) 6
    Gross Weight (KG) 6.5
    Contents AC Power Cord / D-sub Cable / Audio Cable / User's Guide CD / Quick Guide
