DrussTheLegend
Established Member
Hi, I currently have an Denon DHT550 AMP with 6.1 speakers. Whilst it is a good little system and better than what i have been used to in the past, I was looking at upgrading to something like the Onkyo 605. With budget being an issue I wanted to know if it is worth upgrading the AMP if I plane to use the denon speakers and sub i currently have??
(dont have the £ or room for new speakers and Mrs wouldnt be happy either
The spec for the speakers are as follows (taken from a denon pdf)
Centre Speaker:
Type..............................2-Way 3Speakers (P.P.D.D) Sysytem
Frequency Range..............120Hz~90Khz
Impedance......................6 ohms
Sattelite Speakers:
As Above
Sub-Woofer:
Type.......................1-Way 1 Speaker (Active)
Power Output............100W
And if it is worth upgrading then would the Onkyo605 be a good match or are there any better receivers out at the same sort of price range that also support DTSMA/DD TrueHD with HDMI 1.3a & Component switchng?
Any help is appreciated!
EDIT:
Managed to get this more comprehensive info on the speakers from Denon's Website
Satellite Speakers
Model name / number SC-A3L / x4
Construction 2½-ways, closed
Maximum power capacity 100 W / 40 W
Frequency respone 120 Hz - 90 kHz
Tweeter 19 mm
Bass chassis 2 x 57 mm
Impedance 6 ohms
Removable covering
Stable speaker terminals
Weight 1,1 kg
Dimensions (WxHxD mm) 70x210x160
Center Speakers
Model name / number SC-C3L / x1
Frequency response 120 Hz - 90 kHz
Tweeter 19 mm
Impedance 6 ohms
Removeable front covering
Weight 1,1 kg
Dimensions (WxHxD mm) 210x72x160
Subwoofer
Model name / number DSW-3L / x1
Construction Bass reflex system
Maximum power capacity 95 W
Frequency response 29 - 240 Hz
Bass chassis 160 mm
LF Direct
Crossover frequency 50 - 200 Hz (switchable)
Phase adaptation 0° / 180° (switchable)
Variable bass level
RCA / speaker input / -
Weight 11,2 kg
Dimensions (WxHxD mm) 232x452x395
Centre Speaker:
Sattelite Speakers:
As Above
Sub-Woofer:
EDIT:
Satellite Speakers
Tweeter 19 mm
Impedance 6 ohms
Removable covering
Weight 1,1 kg
Center Speakers
Tweeter 19 mm
Impedance 6 ohms
Weight 1,1 kg
Subwoofer
Bass chassis 160 mm
LF Direct
Variable bass level
Weight 11,2 kg
