Is this a good deal?
Discussion in 'Projectors, Screens & Video Processors' started by Sandman, Oct 10, 2003.
  1. Sandman
    Sandman
    Nov 28, 2002
    3,124
    Glasgow
    +705
    I have been offered a 3M 8030 projector for £350. I know nothing about projectors and thought this was a good price, I have since seen that these projectors sell for around this price on ebay.
    I plan on using it only for watching DVD's in a dark room. Will this projector be up to the job and is it worthis for the asking price?
    Your comments will be appreciated.
    thanks
  2. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    http://www.projectorcentral.com/3M-MP8030.htm
    Going from the spec it is pretty much junk ;)
    It's a 4:3 business projector, with a terrible 200:1 contrast ratio, not geared to home cinema at all, but the £350 towards something more appropriate.
    -- Jon
  3. Sandman
    Sandman
    Nov 28, 2002
    3,124
    Glasgow
    +705
    Oh dear, is it really that bad, bear in mind all I want to do is watch dvd's on it. Would the picture be terrible? I cannot afford to spend any more money than this and now really want a projector.
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,309
    Surrey. UK.
    +2,021
    The resolution is very low too - 800 x 600 is really a minimum for widescreen DVDs, and this one appears to only do 640 x 480. :(
    I'd try to save up and get something better to be honest. You may get a second hand Panasonic AE100 for that if you look around.
    Gary.
  5. Sandman
    Sandman
    Nov 28, 2002
    3,124
    Glasgow
    +705
    Thanks for the help guy's I appreciate it.
    I passed on the 3M and just ordered an ex-demo Panasonic AE100 (£599), more than I was looking to spend but I think the difference will be worth it.
    Cant wait till it is delivered!! Is there much to setting these things up?
  6. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    what are you using it with? Standard dvd player? in which case it is not much harder than setting up a tv
    ad
  7. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +174
    Set up is easy. Just point the thing towards a wall/blackout blind/screen. Plug in you DVD via S-Video (component vid if you DVD supports it). Set the projector to cinema mode via the little remote and settle back for a great evenings worth of entertainment.
    Generally, the default settings are quite good straight out of the box just remember that you really need close to blackout conditions to enjoy the picture at it's best. Also, switch the lamp mode on to low in the options menu to double your lamp life and reduce the noise level of the fan (makes a big difference).
  8. Sandman
    Sandman
    Nov 28, 2002
    3,124
    Glasgow
    +705
    I will be using it with a samsung DVD511 player and my sky digibox.
    Well, I'm going over to the DIY forum to find out how to build a decent screen.
  9. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +174
    Well, if it's a screen your after there are two cheap options:-
    * Get a 8 x 4 sheet of MDF and paint it with Dulux Icestorm No.5. I know it sounds strange but it improves the contrast and black level without sacrificing too much white.
    or
    * Go to Ikea and pick yourself up a 2 metre wide white blackout blind called Tuplar. It will only cost around 20 quid and the image on it is amazing. Plus you can roll it up when you've finished watching your movie.
    Both are mega cheap options and will give great results.
