Is this a good deal ?
Discussion in 'Home Cinema Speakers' started by HomeCinemaGuy, Aug 12, 2002.
  1. HomeCinemaGuy
    HomeCinemaGuy
    Hi All.
    I know someone who is selling a:
    Paradigm CC-350 centre speaker for £100 is v good condition is this a good deal. New they cost around £200.
    What do think of the speaker and the deal?
    Steve
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,978
    Berkshire
    +110
    Depends on which front speakers you have - will they match the Paradigm tonally?
  3. HomeCinemaGuy
    HomeCinemaGuy
    Im using some Wharfedale Valdus 500 Floorstanders. I would get the Valdus centre but its to small.
    The Para is 60cm wide which I need.
    Steve
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    If they don't match tonally you may well find that anyone talking who moves around the screen will change his voice depending on which speaker his voice is coming from.
    Not just voices as other sounds will be different from different speakers.
  5. HomeCinemaGuy
    HomeCinemaGuy
  6. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    I made that mistake a few years ago. I had a nice pair of floorstanders and bought a large centre cheaply which didn't match at all.
    In the end I swapped it with a friend's centre which was much cheaper but a closer match.
  7. HomeCinemaGuy
    HomeCinemaGuy
    Would the diamond 8 match do you think. Ive got a very powerfull amp and the valdus centre would not go right at all :(
    Steve
  8. HomeCinemaGuy
    HomeCinemaGuy
    Is the para a good deal u think ?
    Steve
  9. lmccauley
    lmccauley
    Oct 24, 2000
    3,430
    Newcastle
    +268
    Best thing is to borrow them from a shop and try at home. I did this and saved myself a fortune by not buying the so-called matching centre for my floorstanders. Sounded tonally very different - I kept the little Kef 80C which integrated much better, until I replaced all 3 with identical units.
    Cheers,
    Liam
  10. lmccauley
    lmccauley
    Oct 24, 2000
    3,430
    Newcastle
    +268
    That question is impossible to answer unless you know whether it tonally matches your other speakers. If it cost £20 but didn't match, then you've wasted £20...
