is this a faulty speaker???
Discussion in 'Home Cinema Speakers' started by rdt123, Jan 12, 2003.
  1. rdt123
    rdt123
    Dec 14, 2002
    1,415
    Busting out a restaraunt in Queens, NY
    +33
    hi all
    i received a set of diamond 8 speakers today. The sound quality is excellent. Trouble is with the test tones playing the right rear 8.1 is very quiet compared with the other four speakers. ive tried different cabling and have put it on the rear left channel to check the output of the amp but this is not the problem.any ideas or comments appreciated greatly
    tia
    rob
  2. rdt123
    rdt123
    Dec 14, 2002
    1,415
    +33
    Just to add, although there seems a massive difference with the test tones, the difference in sound from each of the rears when viewing a dvd appears negligable
    any yhoughts?
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    so the problem is only with that one right rear.... and is it the right rear speaker (ie. did you meant that speaker worked ok when you tried it elsewhere?) or is it the output from the amp that is low?
    If this sounds partronising, sorry....... have you checked the channel level ok?
    ad
  4. rdt123
    rdt123
    Dec 14, 2002
    1,415
    +33
    The amp shows the output to the rears is equal but when a test tone is heared one of the rears is very quiet although it does not seem so during playback. I've changede over the cables and placed the speaker on a different channel, i.e the other rear with the result that during the test tone that output is very quiet. It seems the speaker is to blame but its a strange one
  5. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I cant disagree with you........ there really doesnt seem to be any other explanation. Id have a word to who ever you bought them from
    ad
