Is this a fault or am I over-reacting?
Discussion in 'Blu-ray & DVD Players & Recorders' started by simonp, Dec 31, 2002.
  1. simonp
    simonp
    Just purchased the LG DA3520 home cinema kit but there is a constant hiss/noise coming from the speakers. This is at its loudest when the CD/DVD is in stop mode but is easily audible when watching TV, listening to the radio, watching DVD's etc.
    Is this a problem or do all speakers suffer from some background 'noise'?
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    No, speakers on their own should be totally silent when no sound is sent to them. However it is a fault that I have noticed with other all-in-one setups such as a friend's Panasonic: the amp does send a constant low-level hiss to all speakers. Probably poor design within the amplifier section. If you can't live with it, ask for a refund.
  3. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    A quick search on another forum :D shows that this is a known problem with this model.
    I'd take it back !
  4. simonp
    simonp
    cheers guys.
    will probably take it back.
    problem is, which all in one system do I go for? Do they all suffer from this low level hiss becasue apart from this, admittedley irritating problem, I am generally pleased with the unit.
  5. sanorman
    sanorman
    Mar 26, 2002
    13
    The same thing happened to me. I called LG and they were aware of the fault, they sent someone to my door to collect the unit (DVD player only) and gave me a new one straight away.
  6. Goof
    Goof
    Oct 14, 2002
    752
    Scotland
    apparently this a problem of unshielded components and lack of grounding - it'swell known for Videologic Digitheatres. It can be solved by getting a length of speaker wire, wrapping one end round the digital out connector on your DVD player and connecting the other to a grounded pipe (ie. the copper pipe at the bottom of a radiator).
    Stange but true and worked a treat for me!
  7. simonp
    simonp
    sorry for sounding stupid but which one is the digital out connector?
