Is this a early sign of DVD rot?
Discussion in 'Movie Forum' started by nathan_silly, Apr 18, 2003.
  1. nathan_silly
    nathan_silly
    I've got the Avia disc, and it has a white watermark-type stain.. see pic. Is this disc rot or just plastic discoloration?
      Size:
      4.7 KB
      2,453
  2. dataloss
    dataloss
    Apr 18, 2003
    89
    11
    London UK
    +14
    Hmmmm I have several discs like that with smear in the plastic, even CD's... but I've not had any problems with DVD Rot... it just seems to be in the plastic itself and not affecting the foil of the disc.
  3. dataloss
    dataloss
    Apr 18, 2003
    89
    11
    London UK
    +14
    just a note to say I'd keep a eye on the white milkyness though if it seems to spread, then return the disc.
  4. nathan_silly
    nathan_silly
    I'll probably make a copy of it (got a PC DVD-R) As long I can fall back onto the DVD-R (if) the original screws up.
    Ta
  5. dataloss
    dataloss
    Apr 18, 2003
    89
    11
    London UK
    +14
    I noticed a lot of PC Magazine Disc's both DVD Rom and CD Rom have the same smeary plastic, probably ether cheap production or poor storage of stock media or maybe both... I had a DVD yesterday that has since been sent back to "Play" that had airbubbles in the plastic that were obscuring the laser from reading the disc..
  6. nathan_silly
    nathan_silly
  7. nwgarratt
    nwgarratt
    May 5, 2002
    27,038
    +2,980
    If the cloudiness is like a coffee stain then I think the DVD will be ok.
    Both my Hellaiser I and II in the limited boxset is like that. They still play fine. I think it is just the glue showing through that hold the different layers together. Some discs are almost transparent.
    The only disc I have had problems is The Terminator and the glue came out from underneath the layers.
    I have also had the second disc of Blade II go bad but that was the amaray case cracking the disc in the centre. They are the only ones out of 300 odd discs.
  8. dataloss
    dataloss
    Apr 18, 2003
    89
    11
    London UK
    +14
    aye, the coffee stain or smear is mostly cosmetic in nature as long as the foil can be read by the laser the disc will play fine, the worst case of Rot I've ever seen was a early 80's CD the foil just flaked off inside the plastic... what is annoying is the film industry is keeping quiet or just plain not doing nothing to resolve issues with glues used during manufacture... maybe they are hoping to make more money by selling you the same disc each time it falls apart... who knows...
  9. B Caine
    B Caine
    Jul 15, 2000
    80
    Barrow North UK
    +3
    Just wash the disc in WARM water and dry, this will cure the problem, I had It on T2 and now is all well. Hope this helps.
  10. nathan_silly
    nathan_silly
    Hmmm recieved a warning for the above.
    Danashmore was in the wrong, not me.
  11. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,417
    2
    In a secret location with Jennifer Lawrence
    +9,112
    Yes, DanAshmoreUK was in the wrong. His post has been deleted and PM already sent. But there was no need to reply abusively.
    I know DanAshmoreUK post was of no purpose and only designed to antognise you, which he succeeded in doing, which is why his post has been removed.
    Greg
