Is this a Barmy Idea ?
Discussion in 'Projectors, Screens & Video Processors' started by ukfatboy, Sep 9, 2004.
  1. ukfatboy
    ukfatboy
    Apr 9, 2003
    104
    Greetings all !
    Some of you might know that I am currently in the painfull process of getting my first projector. More or less settled on Themscene H77/ benq 8700 or infocus 7205, all dlp you might note.
    I have always had the intention of running the projector off my HTPC off dvi.
    As I was thinking about the position last night a mad idea crossed my mind.
    Its now possible to run 2 graphics cards or a dual dvi out card in the pc. So would there be any benefit in running 2 projectors ( both out putting the same image ) at the same time ?
    I assume that brightness etc could be increased etc ?
    Obviously I could then consider 2 cheaper projectors to make up the image and even consider high def capable LCD projectors ?
    Am I Barking :rotfl:
  2. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    BARK BARK
    it is possible but is a knightmare to set up, and would more than likley be a pro install.
    Then theres 2 lots of PJ noise.+the PC.
    Have to say since HDMI whats the point of a HTPC.
    Anyhow good luck if you try it. 2 lots of bulbs regular calibration to sync. rather u than me LOL
  3. UrbanT
    UrbanT
    Jan 6, 2002
    13,281
    Aldershot, Hants
    +3,035
    Woooooofff!
    Its hard enough getting your iamge to fit exactly on a screen, never mind trying to overlay 2 images on top of each other, especially as they would be projected from 2 slightly different angles. I'm no expert by any means but this does sound a little crazy :zonked:
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,269
    UK.
    +2,792
    'Stacking' is tricky but possible - it's normaly done with CRTs when a larger image is needed, but a single CRT can't produce enough lumens.
    Your idea is another step - stacking usualy involves a single output to two projectors, but you're trying two with different outputs (2 x XGA): 2048 x 768 = 2.6:1. With some scaling, I guess you could keep a constant height, and vary the width like in a proper cinema. :)
    Unfortunately I don't think you'de be able to run two graphics cards in the same PC though.
    Nice idea, but a pig to produce. Let us know how you get on. :D
    Gary.
  5. ukfatboy
    ukfatboy
    Apr 9, 2003
    104
    Interesting 2 different opinions !
    I think the HTPC debate is well discussed on the forum but I can tell you that my pc is silent and produces a better picture than my TAG dvd player !
    It is in fact possible to use 2 graphic cards but not easy ! alternatively there are a number of graphic cards that have 2 dvi outputs on one card which would seem to be a easier starting point !
    Anybody else have any comments ?
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    In the past I have stacked two Sim2 Domino projectors to good effect.
    Alignment was easy with the optical lens shift and the remote control zoom.
    I could only feed 2 S-Video signals from a Pioneer 868 but a graphics card with 2x DVI out would be excellent.
    Incidently I wholeheartedly agree about the picture quality using a PC.
    I use a Uvem unit produced by Phil Hale and it is far better than any of the DVD players I have tried.
    Jeff :rtfm:
