Is This 5.1 Receiver Any Good ???
Discussion in 'AV Receivers & Amplifiers' started by istari knight, Jun 17, 2005.
  1. istari knight
    istari knight
    Feb 18, 2005
    61
    11
    Falmouth
    Hi ,
    I am on a tight budget and have seen some tempting receivers.....
    first one is a ELTAX AVR-200 and the other is a ELTAX avr-250.
    the avr-200 is £69.99 and the avr-250 is £89.99.
    What i need to know is : are they any good? how do they sound ? and does anyone know of any other 5.1 amps for a similar price ?( £100 max )
    the amp will be used with a pc based media center ( connected via optical )
    and yamaha nsp-100 surround sound speakers/sub.
    many thanks for any reply's !!!!! :thumbsup:
  2. swanytroon
    swanytroon
    Apr 4, 2004
    956
    +10
    i would be more looking for a proper make if i was you.
    eltax are knowin for good budget speakers but as far as i know there amps are complete rubbish.
    it also just happens that im about to sell a yamaha amp seen here
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1440
    for your max budget plus del
    if your intrested il start a new thread in the for sale section.
    im not just saying this cause of what im about to put for sale but ask anyone it would be alot better buy than the amps you have said.
