Is there such a unit?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by jem, Jul 14, 2003.
  1. jem
    jem
    Sep 24, 2002
    527
    +7
    I'm looking to but an av receiver and initially hooking up a dvd player to it. At the moment though I'd like to still use my mini hi-fi for its mini disc and CD, but unfortunately it has no outputs at all other than speakers.
    I'd obviously prefer to have one set of speakers. Is there such a unit that I can attach to the av receiver and the mini hi-fi which will then attach to the speakers therefore allowing me to choose which component can use the one set of speakers?
  2. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    68
    Leicester
    +56
    One of these should do it. You can get cheaper ones than this I got one (can't remember the make) off ebay for £5. But QED are quite well respected so I don't think you can go wrong with it.
