blackbrickblock
I would like to have a card reader to fit the floppy bay but is there another way of connecting the thing up?
Something like this
http://www.aria.co.uk/Products/Comp...1+Card+Reader+Black+with+USB+?productId=24902
or
http://www.misco.co.uk/applications/searchtools/item-Details.asp?EdpNo=296227&sourceid=2672
I've never used the companies, so I can't comment on them.
I think you could use something like this
http://www.expansys.com/zoompic.aspx?type=item&i=111297
A PCI card with extra USB's (External) and 1 USB on the inside.
Then connect card reader to the internal USB port.
Also are you front USB ports using one or two motherboard headers ? Is there a spare header available
