Heh, my bad. Ok, Just one scart output witch will go to either a 15inch TFT or a 30-summit inch CRT. Dolby+DTS output, opt or coax I don't mind. Budget doesnt really matter as long as it's not X amount of thousands of pounds.
Most mid ranged players (£350-£700) are reasonably well built it's just a case of finding one that has the conectivity and functionality that suits your needs. A trip to a local dealer is required to test the usual suspects being, Denon, Arcam, Pioneer, Toshiba, Sony etc. You may well find that you might be better off buying second hand as the older players seem to have been much better built. My Sony is built like a tank and gives superb PQ and SQ for a player thats over 3 years old. I haven't felt the need to replace it as it does everything I need and it does it very well. You can pick a mint version of my player up S/H for around £100
