Is there anywhere cheap(er) to buy B&W speakers?
Discussion in 'Home Cinema Speakers' started by beem, Apr 25, 2005.
  1. beem
    beem
    Mar 9, 2005
    117
    lahndan
    Hi, just looking for any advise you guys might have. I haven't posted often but have based my choices so far on your collective audio musings...
    I really want to find a pair of B&W 601 s3's in sorrento but can't seem to find any second hand so i think i might need to get a new pair. The list for these seems to be 250 quid, but is there anywher that sells them cheaper? or is it that they sell so well no one reduces them?
    Any help would be appreciated.
    Thanks,
    B.
  2. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    You will be hard pressed to find B&W at any price below the MRP, you could either look round for exdem or try to negotiate with the dealer.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Why should they be any cheaper? If you listened to them and don't feel they are worth the money then maybe you should be looking at cheaper speakers. Alternatively if you listened to them and are happy with the value for money then just buy them, they are great speakers for a pityfully small amount of money. I'm sure if you asked nicely your dealer would do you a deal on some better sepaker cable or interconnects.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    I'm not sure about the remarks above re a pityfully small amount of money....yes,in overall terms,B&W offer very good value throughout their range,but I'm sure that most customers will still look for whatever discounts they can get.
    I personally was happy with what I got from my local B&W dealer,who found it possible to add a bit of value to some bits I was trading in at the time.....as Crusty suggests,whilst you may not get a traditional discount(and a number of other brands,Linn in particular,operate that policy),you may well get some cables or I/c's thrown into the deal.
  5. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    I've seen this sort of thing said on this message board quite a lot and I have to say, I'm baffled by it.
    What's wrong with trying to find the best deal you can get? Waitrose sell things for about 10 or 20% more than Tesco do, so people shop at Tesco. It's not a question of what I value something at, it's a question of what the market will take, and if the competition is selling it for less, then good for them. It's called capitalism. I don't really trust the company that makes something to tell me how much they think their product should be worth, thanks very much.
    You know that DVDs have an RRP of somwhere between £20-£25 on new release don't you? I'll bet you only buy them from shops that sell them for their full price, right? No, you don't, because why spend more for the same product if you can get it cheaper.
    This isn't having a direct go at you, mate. I can see your point of view, but I just don't think it's fair to say 'pay what they tell you to pay' just because they tell you to pay it, and there's nothing wrong with trying to find the best deal you can for yourself. :confused:
    To the OP, try ebay. There's normally quite a few of them on there. Because of their relatively low price, though, they tend to sell for not much less than RRP, so it might be worth thinking about how much the full warranty you'll get from a dealer is worth to you. :smashin:
  6. beem
    beem
    Mar 9, 2005
    117
    lahndan
    bit of a can of worms there. anyway, i probably will buy from a dealer as someone pointed out, they go for almost rrp on e-bay anyway. I was just asking, not to open a thread on monopolies, capitalism or value but I thought someone might say 'go to www.xxxxxx, they're 20 quid cheaper'. Unfortunately it looks unlikely so I'll just have to pay the going rate i guess - being a jock, I find this an affront to all my better judgement.
    Thanks for the replies a though.
    B.
  7. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    unilet sound and vision, in new malden
    the blue murder sale
    they should be able to help.
  8. beem
    beem
    Mar 9, 2005
    117
    lahndan
    thanks for the tip. I've put my name on the mailing list for the sale, but I'm guessing there won't be ny mail order or holding stuff during the sale so we'll see...
    thanks again,
    B.
  9. Helicon
    Helicon
    Apr 4, 2005
    5,018
    +261
    I agree with crustyloafer - why should they be any cheaper? B&W put a lot of r&d into their speakers and manufacture decent quality drive units, unlike many other manufacturers(Mission/Wharfedale etc who buy cheap ones). If they weren't worth every penny of £249.95 B&W wouldn't price them at £250. If you don't think they're worth £250, buy some you think are, or if you don't want to spend £250 fullstop, spend £200.
    Many may be baffled by this, but this baffles many........
  10. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    But as you have experienced, B&W pricing policy has a flow on effect to the resale value (should you ever try and sell).
  11. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    Take a look at the offerings of www.av123.com, both "Rockets" and Reference speakers are good value. Rocket 750's and 850's have been compared with N803/N804's, at a fraction of the cost.
    Unfortunately it will prove difficult to demo a set, because few people have them in England. I was willing to take the gamble, and am very happy with what I got.. :thumbsup: :cool:
  12. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +883
    Without wanting to restart another copy of the long thread on the front page of the forums.....
    I am sure that B&W do put a lot of r&d into their speakers and that they use high quality parts. This should be reflected in the price that they charge to retailers. It should then be up to the retailer what price they want to charge to customer their customers- obviously the higher stock price will result in a higher sale price but the actual sale price would/should reflect the business model, target profit margin etc
  13. Helicon
    Helicon
    Apr 4, 2005
    5,018
    +261
    I'm not even going there again........
  14. beem
    beem
    Mar 9, 2005
    117
    lahndan
    Thanks for the unilet sound and vision tip off (inside job?). Bagged a pair of ex domo 601 s3s for 149 quid - though I have yet to see them and confirm the condition. Anyway at that price though they are WORTH 250 it represents good VALUE to a tight wad like me.
    See, the best things come to those who wait, etc. etc.
    B.
