accesories aren't as ubiquitous as Apple. however you can buy a dock and anything which has a line in or a 3.5mm jack works fine.
If you want to find out more about Cowon/IAudio take a look at http://www.iaudiophile.net
Simple - No - you can't do better than an iPod. Now there's a sweeping statement that's bound to upset a lot of people; but are they the same ones who knock Bill Gates and Microsoft?
Simple - No - you can't do better than an iPod. Now there's a sweeping statement that's bound to upset a lot of people; but are they the same ones who knock Bill Gates and Microsoft? Probably! It does what it says on the can, as a famous TV advert once said. Can't get on with iTunes? I couldn't work out some of the excel formulae I needed, so I worked at it and guess what? That works as well. Still this is the right forum for you to get opinions from lots of people, both for and against.
not sure if there are any really drag and drop solutions out there.. i have a friend who says he can drag and drop mp3's using windows explorer onto his creative nomad... he can but to do it he has to installed a pluging to windows explorer first! so is it really drag and drop?
My Samsung Z5 is drag and drop, just like any USB stick, there is no software required, select UMS on the menu, plug into USB port and thats it.
I personally prefer ipods myself, tried most of the others and i think the ipods all round package is the best.
Also the new ipod video is probably the best sounding mp3 player i've heard.
looks like a nice player karkus... how does it manage album art and playlists? do you have to use a program of id tagging?
Cheers,
Mick
Well I think the Samsung Z5 is, no no I mean the Cowon X5, nope thats not it maybe its the Iriver or the Sony ? No Im sure its one of the iPods or.......
and not one mention of alternative earbuds! The piece of kit that really allows you to tell the difference between players.
Who wants to list iPod negatives and positives..........dont mention the battery (remember all batteries have a finite lifespan of a couple of years maximum and quite often this can be reduced to around 12 months) which is not user replaceable or being forced into using iTunes, which are far from the only de-merits.
I think you can say that the iPod has the most intuitive interface (but its far from perfect....try selecting volume quickly!), it has many of the glitches ironed out as it uses iTunes (but I hear the latest version has been quite buggy), it has the most add on accessories, its one of the nicer looking players.
