Is There Any Point Buying The Trilogy???
Discussion in 'Movie Forum' started by Pebble, Oct 20, 2004.
  1. Pebble
    Pebble
    Nov 18, 2003
    311
    Grangemouth
    +4
    As per title -
    IS THER ANY POINT BUYING THE EXTENDED TRILOGY when you can buy the individual extended versions for less???
    R2 Fellowship extended £11 here http://www.dvdsontheweb.co.uk/ProdDet.php?cd=EDV9171&c=dvd&source=find-DVD
    R2 Two Towers extended £11 here http://www.dvdsontheweb.co.uk/ProdDet.php?cd=EDV9188&c=dvd&source=find-DVD
    R2 ROTK extended £15.50 here £2 off with voucher http://www.sendit.com/video/item/7000000096186
    OR
    R1 ROTK extended £14.55 here http://www.dvdsoon.com/show-title-details.xml?uid=115168&partner_id=1005
    Total for the 3 individual versions is £37.50 or £36.45 (R1 ROTK)
    The cheapest I have found for the R2 extended trilogy is £41.49 here http://shop.game.net/ViewProduct.aspx?cat=5&mid=324871
    Save some £££ and get them individually
    If you want to go down the full R1 route for the better packaging + no so called audio glitches www.dvdsoon.com do the 3 individuals for £48.06 which is cheaper than most places for R2 trilogy.
    Dvdsoon do the R1 trilogy for £48.52 , but theres no point getting stung for tax which would take it to >£60
    Pebble
