Is there an optical cable splitter?
Discussion in 'Xbox Forums' started by BuFF DaDDy, May 7, 2007.
  1. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    Right, I currently have a DVD player with amp built in. At the moment it takes my 360 optical cable for 5.1 surround sound.
    I would also like my PS3 to play in 5.1 also, but my DVD player only has one optical in and one optical out. Is there an optical cable splitter/plug that will allow the dvd player to take both cables?
    Any help appreciated.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,541
    Canterbury, Kent
    +1,182
  3. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    Thanks Poon, appreciated.
  4. 2010
    2010
    Oct 1, 2005
    942
    W4
    +52
    I think this is more suitable for your needs.
  5. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Isn't that the wrong way round?
    Don't you need a switch rather than a splitter ( something like this http://***********/28pgbu )
    edit: beaten to it.
  6. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    the switches involve getting up and manually turning the switch to the next input.
    the splitter allows you to have 2 to 1,or 1 to 2,without all the faffing about,and its cheaper.
    as long as only one of the inputs is on at a time,its fine.
  7. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    I thought an optical splitter won't work in reverse. doesn't it rely on having laser diodes and receivers.
  8. KirkSi
    KirkSi
    Mar 1, 2005
    7,836
    167
    Manchester
    +3,910
    I've got a similar splitter and use it to go the other way i.e. integrate signals from 360 and PS3 into one input in my amp and it all works fine (as mentioned as long as only one source is on at a time!).
  9. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    Thanks for all the helpfull advice guys.
  10. Schumi 01
    Schumi 01
    Dec 12, 2005
    1,521
    +375
    I agree, i use one of those splitters, and it works great for me. :thumbsup:
  11. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    And me :thumbsup:
  12. derek1971
    derek1971
    Mar 13, 2005
    2,228
    Glasgow
    +300
    i use that splitter too for putting both 360 and PS3 optical cables into my amp. You will need another optical cable too - this connects the splitter to the amp.
  13. def
    def
    Feb 21, 2004
    1,909
    63
    +142
    Bizarre! I bought that exact splitter from Maplin and it doesn't work for me at all. Maybe I have a dud one then.
  14. Nivek TT
    Nivek TT
    Feb 27, 2006
    6,565
    Bristol
    +2,132
    My amp only has two optical inputs and I'm finding that too few.
    What happens if both devices are on at the same time, nothing..?
    I'd really like this for my Virgin V+ box and Stereo system, I'd never use both at the same time. At the moment the stereo is phono-wired into my amp but there is a really noticeable improvement when fibre connected.
    The maplin faq claims it cannot be used to combine 2 inputs into one output. I really don't want to have to rely on a switch!
  15. rikki2ks
    rikki2ks
    May 4, 2006
    1,430
    Ipswich
    +173
    I use it for my 360 & Sky HD and it works just fine :thumbsup:
  16. derek1971
    derek1971
    Mar 13, 2005
    2,228
    Glasgow
    +300
    My amp also has 2 optical inputs. I use one to connect my Sky HD box. The other one has one of these splitters in it with an optical cable coming from the amp into the end of the splitter with only one input.
    At the other end of the splitter i have 2 optical cables - one from the 360 and one from the ps3.
    To get the sound from the Sky HD box i set the amp to "video 1". To get sound from either 360 or ps3 i set the amp to "video 2".
    This works perfectly well despite what the FAQs on maplins site say. I remember reading in the FAQs that the splitter can only be used to take one output and send it to 2 other devices not to take 2 inputs and put them into one receiver but as long as you only use one input at a time it is fine. I was also told by the guy in Maplins when i bought the splitter that it wouldn't work and i was wasting my time and he would be waiting for me to return it. What great advice! Needless to say he is still waiting.
    In so far as having both input devices on at the same time that obviously doesn't work. I get a strange mixture of both sources if i do this (or occasionally no sound from either) But since you don't intend to use both sources at the same time that won't be a problem.
  17. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    i too have tried these optical splitters and cannot get it working from 2 sources to one input, i have tried 2 different splitters, the one described similar to the Maplin one and also a manual switch where you turn this...thing (cant think of thw word!) to get different sources, is it me?!?
  18. Korum
    Korum
    Feb 19, 2005
    4,423
    Stockton-on-Tees
    +713
    This is interesting as my Sky HD box produces a null signal with the optical and keeps turning on and off even when the Sky HD box is in standby.It causes havok with my optical selector box.
    Does this work perfectly with your 2 sources?
  19. derek1971
    derek1971
    Mar 13, 2005
    2,228
    Glasgow
    +300
    i have both 360 and ps3 working through a 2 way splitter and haven't had any problems
  20. Korum
    Korum
    Feb 19, 2005
    4,423
    Stockton-on-Tees
    +713
    Yeah, those 2 aren't a problem because the optical signal turns off whenever the 360/PS3 are put into standby, SKY digibox optical signal are different, some are constantly on and some turn on and off intermittently which causes all sorts of problems with splitter/switcher boxes.
  21. J273
    J273
    Aug 8, 2006
    1,521
    Swadlincote
    +31
    Ahh thats what my problem is ..No wonder i couldnt get mine to work from maplin.
    I was planning on using it with just the 360 and ps3 but tried the sky box and thought the splitter wasnt capable of doing two inputs to 1 output.
    Ill have to give just the ps3 and xbox a try....I have noticed my sky box is always outputing a signal :suicide:
  22. Korum
    Korum
    Feb 19, 2005
    4,423
    Stockton-on-Tees
    +713
    It'll work perfectly with the PS3 and xbox as long as both aren't turned on at the same time:thumbsup:
  23. julianwood
    julianwood
    Feb 22, 2006
    10
    Another great option is to use an optical to coax converter. I have one optical and one coax input on my amp and two optical sources (Sky and 360).
    Put in one of these converters and you can then use an optical out from your 360 to a coax in on your amp.
    No switching required or one off and one on!
    Optical In Coax Out
    http://www.maplin.co.uk/Module.aspx?ModuleNo=29293&criteria=opticalconverter&doy=9m5
    Here's the converter for the other way round
    Coax in Optical Out
    http://www.maplin.co.uk/Module.aspx?ModuleNo=29291&criteria=opticalconverter&doy=9m5
  24. Noddy1878
    Noddy1878
    Jun 1, 2006
    65
    Bournemouth
    +3
    I am using the splitters with no trouble at all. In fact i have my 360, ps3, DVD player and DVD recorder all going into the same optical input using 3 of them. Not a single problem. If more than one device is on at the same time i get nothing. Sky HD has an input all of it's own because of the fact it's never off as already mentioned.
  25. AkheirAX
    AkheirAX
    Mar 13, 2007
    557
    +29
    I have bought the Optical splitter but that my friend is something I think i shall invest. I have both 360 and PS3 on at the same time most of the time. Thanks for link.
