Is there an optical adaptor cable?
Discussion in 'Cables & Switches' started by wattsj, Sep 24, 2004.
  1. wattsj
    wattsj
    Problem:
    Sony DAV-s880 had one optical input.
    I have Sky+ and Panny E55 that both have optical outputs.
    Is there an adaptor\cable I could connect into the 800 and connect both the Sky+ and E55 into.
  2. John
    John
    Dec 13, 2002
    11,504
    +3,131
    you need an optical switch or splitter used in reverse .Try a search ,both have been covered quite recently :smashin:
  3. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,486
    Rainham Essex
    +2,487
    or just £7.99 Here and they are one of the forum sponsors :smashin:
    Mark.
