Is there an app that...............
Discussion in 'Apple Forum' started by davemulheran, Jun 11, 2009.
  1. davemulheran
    davemulheran
    Dec 27, 2007
    1,688
    48
    +67
    ... lets you create a list of what you have in your iTunes?
    Example, I have 120GB of music and would like to send a list of what I have to a friend.
    Is there a way of getting the data in a document / text ?
    merci! :thumbsup:
    EDIT-- for example, in itunes, I can just go to file -- print and then 'album listing.
    but this actually prints out the list.
    I want it as a file so I can email / view.. if that makes sense
    EDIT 2..... found out how.. you can 'print' to a PDF file
    sorry, please ignore my inane ramblings
  2. CamFire
    CamFire
    Apr 26, 2009
    4,693
    Cambridge
    +600
    Will Export do on the selected playlist/album? A text file results, although the formatting looks requiring some work.
  3. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    There's a text editor called Text Wrangler that you can drag the folder of your iTunes Music into and it will create a folder/file list of all the contents.
    I use it all the time on my Movie folder so I know what I've ripped so far :smashin:
  4. davemulheran
    davemulheran
    Dec 27, 2007
    1,688
    48
    +67
    Cool, some other options, thanks guys.
    Just incase anyone didnt know... iTunes can do this.
    Select music or whatever playlist you want (i wanted the whole lot)
    File ----> Print
    select album / song listing
    Print
    then select PDF
    I mailed one to myself and its very good/clean
  5. CamFire
    CamFire
    Apr 26, 2009
    4,693
    Cambridge
    +600
    Just discovered that reading this exported TXT file with OpenOffice as a spreadsheet (or Excel if you have MSOffice) results in a really neat layout which you can manipulate easily.
