Thanks for the replies on my previous post of a bad RGB signal, which is supposed to be the best..After a reply from shaun the problem seems to be that there is a fault with the 747 connected through RGB to a Panasonic TV.( which is mine)
Is there a way to solve this myself with a purchase of another connection ie: componant to S-video scart? to get the quality of the picture that I purchased this DVD for.
Or do I take it back and ask to fix the problem or even to swap machines.
The main reason for purchasing this machine was the picture quality I read in masgazines. The DVD-a and SACD was a nice add-on, but a really clear picture the most. I am very disapointed at the moment and not sure which direction to go in.
Thanks for your help if you reply,
Phill
Phill
