Is there a way to play PS3 on separate tv through wifi
BluesyRock
I was just diagnosed with covid and am locked up in my bedroom for a while. I have a PS3 in the living room that needs to stay in there since my kids play it sometimes. When they're not playing it, I was wondering if there's a way I can play it through wifi on my Samsung smart tv that's in my bedroom. My bedroom is close enough to the living room that the controller works. I know I could do an HDMI splitter but I don't want to spend the money on a splitter and the long HDMI cable. Not to mention the time it would take to have them delivered. I'm hoping someone knows a way. Thanks!
Jamie
Do you have a laptop with HDMI, you can play using The Sony remote play app. I use my MacBook sometimes to play like this and it works quite well.
Upvote 0
BluesyRock
My laptop does have an HDMI output. How does the remote play work? My laptop is 10 years old so I doubt it could handle processing a PS3 game.
Upvote 0
Jamie
There's a video showing remote play in action. I've just realised you said PS3 and I actually use the PS4 version but the idea is the same.
Upvote 0
Jamie
I had a quick look specifically at PS3 remote play, looks like it's not necessarily as simple as PS4 remote play. Worth a try but it might be a good opportunity to upgrade to a PS4, the kids will thank you as it's a much better console than PS3
Upvote 0
