Is there a Service menu for the Sony KV-X 2962?
MLAM
Established Member
Joined
Dec 16, 2001
Messages
650
Reaction score
81
Points
143
Location
South Wales
This is a HiBlack Trinitron Sony 4:3 TV, it is about 8 years old and I was wondering if there is a way to get into the service menu of this TV.
Any one know?
thanks
Turn the set on with front switch while holding down two of the front panel buttons, release them after a couple of seconds. Screen should display TT.
Not 100% sure this applies to your model, but it works with my KV-X2572
Ok it does display TT when I do what you said
Then what do I do to get into the menu?
Continue as follows:-
on remote>Menu>Demo. This allows you to access the various settings, but remember the golden rule Change Nothing without noting the original setting.
To leave service menu key 00.
Hope this helps, what is it you're trying to adjust?
HELP!!
I have buggered up the geometry settings and I didn't write the originals down,
HowieC: Can you tell me what your settings you have your Geometry on?
Its Menu :CXA 2018 on my TV, not sure what your one says though, please reply ASAP
Oh Dear!
I have some bad news and some worse news.
I replaced the set last week, and I havent a copy of the settings.
I'm not sure my settings would have helped though, because they are very different depending on what CRT the set has.
I have a copy of the service manual and the only settings it quotes are
HV COMP.V 12
HV COMP.H 8
H SHIFT 26
Once all the settings are changed its a bit like setting up after changing the CRT very tricky.
One of the service manual pages has pictures of what each adjustment does. I havnt got a working scanner at the moment but if you have a fax I'll get a copy to you. Or post you a copy if you want, let me know.
Nah, thats ok HowieC, I have adjusted it back so it looks just about straight and no curves.
P.S what set is your replacement?
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
