is there a link or more info on using denon 3802 other than the manual
Discussion in 'AV Receivers & Amplifiers' started by mick23, Mar 23, 2002.
Tags:
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    any info setup etc other than denon manual pdf etc can someone suggest a r2dvd with dts to try with 3802 thank you
  2. burkey
    burkey
    The Gladiator has a good DTS soundtrack with great detail.
  3. denonman
    denonman
    SE7EN is another good movie to listen to on your 3802, as is T2..:D
  4. Neol
    Neol
    Go fo Terminator 2, very good DTS
